1 - 14 of 14 Posts
· Thug Engineering ST185's
just a quick one...
have installed the computer and with a very small amount of movement on the throttle position switch the sensor throws a 100% motion...
is there spomething else i should of done ?
i have swapped the sensors with others but same problem..
HELP!!!!!
Cheers
Stu!
Discussion Starter · #2 ·
i forgot to mention
i kept my FCD on the same set-up
is this possibly clipping a signal on the map sensor and causing a problem ?
any suggestions appreciated
Stu!
Discussion Starter · #4 ·
so if i swap the connection the FCD is NOT AN ISSUE ?
is that right ?
Cheers
Stu!
Discussion Starter · #5 ·
which wire should i of connected it to? i thought htis one was the right one ?
Cheers
Stu!
Discussion Starter · #7 ·
i have linked it at the ecu :disappoin
as thought that might of been easier....
how wrong ?
its a JDM 185 and linked on the middle (smallest one) bottom row 3 from the right
HELP!!!!
Cheeers
Stu!
1990 Celica GTS
Wire color is the same at the ECU plug.
I did mine at the ECU too. I spend a few hours with my behind on passenger seat and my head under glove box. Not a comfortable position.
Did you calibrate the SAFC? Go to sensor check menu and see if voltage change when you press the paddle.
Discussion Starter · #9 ·
it was black and something i cant recall..will have to check in the morning
which one did you attach it 2 ?
Cheers
Stu
Discussion Starter · #10 ·
morning can wait :-
as much info as possible
ive got it going to the pink wire at the ecu
throttle off is 0.280v pedal down is 5.115v
flap is 02 in and 02 out (hotwire is the same)
presser is 01 in and 01 out
Discussion Starter · #12 ·
reading my manual i was under the impression that the wire i have connected is correct
so which one is the right one ?
sorry to trouble and thanks for help
Stu!
1990 Celica GTS
Sometime manual has mistake. Sometime we count the wrong wires. It suppose to be the Pink /w Black stripe. Take a look at the TPC and see what color wires are there. There is only 4 wires. So all you got is 3 more to try ;)
I spiced all of them when I put it in my Corolla to find the right one. In the end I found out the TPS was switch type, not resistance type.
Discussion Starter · #14 ·
pink and black seems ok
will keep posted if any probs!
Thanks
Stu!
1 - 14 of 14 Posts
