1 - 12 of 12 Posts
Jaggin'
2007 BSP X-Runner
I am looking to get my armrests wrapped in black suede. I was told by a member on another forum that their was a thread on how to remove the armrests here on toyota nation. Can anyone point me in the right direction?
Call me Nate
2005 Tacoma DC TRD S
Tacomaholic
07 Tacoma Prerunner
let us know how the install goes, im thinking about doing this.
Call me Nate
4 of us are replacing our armrest fabric with black neoprene once I visit Wet Okole to pick up my new seat covers. They sell their neoprene in sheets of 4'x8'.
I'll make sure to post install pics.
Tacomaholic
07 Tacoma Prerunner
alright thanks
Jaggin'
2007 BSP X-Runner
Discussion Starter #7
I am kind of concerned though seeing as those trucks had power nothing and mine has power everything. Hopefully taking it apart wont turn out to be a huge pain in the rear.
Call me Nate
Don't worry about it...I've had my door panel off a number of times and it's a cinch! Just a couple connectors to disconnect.
Here are some written instructions from a door speaker install (sorry no pics):
To remove the door panels, first unscrew the two screws in the panel. One in the door release handle, the other in the armrest handle. You will have to remove the sail panel(plastic panel where the outside mirror is opposite of)
IMPORTANT: When removing this sailpanel make sure to take out the white clips afterwards. If you try to snap the panel back in with them still in the door you will end up pushing the white clips down into the door. So take them off and place them back on the sailpanel, then reinstall sail panels.
Remove the anchor plug on the door panel that's under the sail panel.
Roll down the windows.
Once you have the sail panel, screws and anchor plug out you will seperate the door panel from the door starting at the bottom rear of the panel. You can just pull them off with some force, or if you have a door panel remover tool(like a v ended screwdriver) use that.
Once the doorpanel is loosened pull up on the entire assembly and the panel will be off the door.
Roll the window back up.
Disconnect the two plugs that the power windows and door locks are connected to. Now the panel will be completely detached.
Jaggin'
2007 BSP X-Runner
Discussion Starter #11
I have a problem with the whole posting pics things on these forums, but I will get a buddy to help me out with it. (Yes I know...computer retarded). You gotta see the finished product cuz you helped me out. Don't worry. I won't jip you.
1 - 12 of 12 Posts
