So I went to replace some of the ATF that came out of my camry this weekend when changing the cv joints and I checked the haynes manual about what kind to use. Right in the 1st chapter, it says to use dexron II which is obsolete now, but dexron/mercon 3 replaces it, so no problem. So I go to add the fluid and put in probably 2 quarts or so and then put the dipstick in. I pull the dipstick out to check it and notice the dipstick has writing on the end of it. It was so dirty, I didnt see it previously, plus its 10:00 here and pitch black outside and I am working by the light of the garage. I read it and it says to use toyota type T fluid only.
WTF.
My alltrac takes TYPE T fluid, yet the damn haynes manual says to use Dexron II.
Totally different fluids that are not compatible. Couple this with the fact my tranny drain plug is rounded out and is seized in the pan..
I'm just going to let it sit in the pan without driving it and hope for the best. I am not going to drain it tonight..
WTF.
