1 - 14 of 14 Posts
Camry
I have KYB GR2's, I have B+G springs, I still have a ton of body roll. My question is.....Will the swaybars from whiteline make a huge enough difference in body roll for me to actually get them? This cars suspension needs some serious viagra!
· JUST RE ENGINEER IT
98 Prizum
you are always going to have some simply because the axles run under the car instead of through it, the car is way too far off the ground and is kinda tallish and narrow
I have a 1988 camry wagon 4 cyl, 5 spd. I put KYB GR-2's, Intrax springs, and front and rear Whiteline bars, and currently running soft snow tires. This is the best suspension I've had on a camry. It isn't like an exotic, but the bars sure keep the car flat. Just make sure if you go with the bars you search all the past posts on them. Make sure you get a hardware kit with them, and you are going to need to pick up some different washers than what they give you for the passenger side.
98 Camry XLE V6
^ i have the gr2's with tein H. techs...it feels like stock but lowered...lol
GR-2 are basically a premium oem replacement. I know i wish i went with some Tokico's.
The sways will help, i have the rear whiteline. I wont get the front one because i get enough understeer as is.
my sig tag shows how much my car still leans with my setup.
· NYR
Maybe you have some bad bushings somewhere, cause all it took for me was a fresh set of struts to get my Camry to feel "SWEET" on the turns!
· Insanity makes more sense
1990 camry
i just recently installed kyb gr2s and intrax lowering springs. so far i have been fairly pleased with it. it is noticably stiffer than my old suspension was. I am not sure how the body roll will be yet for me though, still have yet to autox the camry with the new set up. I am concerned about body roll though, because I'm going to try to stick a set of big tires in there, and I don't want them to rub. I guess I'll figure it out after a while.
this whiteline sway-bar i have been reading a lot of lately. how good is it? worth buying?
1998 Camry CE
I find tha tthe rear sway bar really improves andling for the ON/OFF ramps on highways.
I have bought the front bar, but have not put it on yet.
Camry
Discussion Starter · #13 ·
RningOnFumes said:
You know KYBs are closer to stock then Tokicos are?
yeah but at the time I didn't have re-sealable struts.
Anyway I'm meeting with some of the local auto-x guys and they've told me about a few companies who do custom suspension work. What they have recommended is a custom setup with Ground Control Coilovers and sending some stock struts off to koni so that they will make custom inserts for them. Apparently koni has a program for this. So I'm going to look into it more but I'll buy the sway bars first and stop at home depot on the way home for extra bushings.lol
Camry
Discussion Starter · #14 ·
atobe said:
of course but it's not going to be like an F1 car
I wish it would just handle as good as the stock 2005 civic si I use to own.
1 - 14 of 14 Posts
