I'm looking into a full system for my '05 double cab. I plan on building my own box for behind the rear seats to house two 12" Kicker Comp VT 07CVT122s and an amp to power them in the middle. I want to run components in front. I would also like to keep my factory non-JBL head unit if possible. I was thinking the Scosche SLC4 four-channel line output converter would help me add preamp outputs. I was looking at the Rockford Fosgate 3SIXTY, but I'd have to have a $600 Palm device to adjust it. My questions are:
1: Are there any better subs I should use? ($200 or less each)
2: Which amps should I use to power the subs and components? ($?)
3: Which component set should I use? (under $250)
4: Is it possible to use my factory head unit?
5: How many sq. ft. of Raamat or equivalent would I need to cover the roof, floor, all four doors, and back wall of the cab? ($?)
6: How many sq. ft. of ensolite?($?)
7: If I can't keep the stock head unit, what would you recommend? (under $300)
