Audio System replacement
971 Views 1 Reply 2 Participants Last post by  MrSo0h0o
I am replacing the failed JBL stereo/CD/cassette player in my daughter's 2002 XLE. The wiring harness plugs into the old unit using a single 20-pin socket and I am trying to find the harness adapter that matches that socket. The audio stores sell an adapter kit that comes with two different connectors, a 10-pin and a 4-pin, neither of which match my harness. I don't want to cut into my harness. Any suggestions?
1 - 2 of 2 Posts
when your radio is pulled out, look at the bottom inside the hole, basically where the top of the compartment is. you will see two harnesses attached to the plastic. disconnect these and use the plugs that you bought(10 and 4 pin). i believe this will bypass the JBL amp though.
1 - 2 of 2 Posts
