After reading about the tranny fluids I doubt there's an issue there. Did you scan for the codes?
Year and miles on the vehicle. Any othr work done like brakes or tires around the same time? Sounds like it's in fail safe mode. On some cars if an abs sensor fails or the brake light/neutral safety switche does it will cause these types of issues. Do all your lights including brake lights work properly and does the car startas it should but just won't move.
Getting the DTC codes from the ECM by scanning it will help a ton.
Have you turned the Trac /VSC on or off and if so is there a change?
Weather there's a correalation with the earlier repairs is sorta moot unless you think you have a wrranty issue to pursue.
