Since acquiring the new T-100 (1998 SR5 2WD 3.4L auto Xtra cab) with 306k on it...I knew it had a few problems.
Leaking power steering rack and stiffness when turning right
Dirty throttle body
Original timing belt/water pump
Work vehicle
Whining sound from engine/transmission
Varnish buildup
Slight oil consumption
Doing some research, Auto-RX (ARX) seemed like it would be a good choice to run through this truck and see what it can do fer it. Just ordered 8 bottles and it should be here within a week or so. Hope it can do something about the steering rack and clean up the engine internals a bit. Gonna stock up on some SuperTech oil filters (Walmart) and some SuperTech conventional oil. Guess I can put the ARX in the differential as well...
How many of you have tried this stuff? Did it work fer you? What did you use it on?
Dirty throttle body
Work vehicle
Varnish buildup
