1 - 3 of 3 Posts
1995 T100 2WD & 1993 MR2
Is it what you had hoped?
Having done that I highly recommend everyone challenge themselves to give it a try and not get addicted. :cool:
Camreee
'99 Auto V6 Camry
Way more fun than I had thought it would be trying it out a year ago on snow tires.
I was going WOT up to 65-70 mph through those slaloms while the rear tires were sliding around and that was so much fun!
First couple events I thought I would be heading into the grass if I didn't brake hard so the rears wouldn't lose traction, but after a bit I realized I could just let the rear tires slide around as much as they want as long as I was on the throttle partially. Apparently WOT is a pretty reliable get out of slide free card with this suspension and FWD :D
Next event I'm going to put my snow tires (1-2mm tread, 5 inch sidewalls, 50psi) on the rear end and see if it can go even faster around slow corners or if the back just turns into a smoking mess. They're junk anyway and gotta burn em up before it snows or they go to waste, can't think of a more fun way to do it :D
I'm pretty sure you can't not get addicted to this 😂.
1 - 3 of 3 Posts
