1 - 20 of 24 Posts
I have a 2018 HL, SE. It has the anti-collision braking. I know it is functioning when using cruise control on the highway because it does a good job of slowing the HL down when I get too close to a car in front of me.
Does it also work when the cruise control is off?
'18 HL Ltd, '19 GMC Acadia Denali, '02 Honda Civic EX
Yes
My question is do the brake lights come on to warn traffic behind me when the anti-collision system slows me down?
Yes
Auto-braking won't slow you gently the way the adaptive cruise control does.
It won't activate until the last possible moment before it thinks you are going to hit an object. Then it will threshold brake (think "panic stop by an expert racing driver"), which is a very dramatic experience if you're not used to it.
Before the vehicle actually brakes, it first takes up all the slack in the braking system getting ready. If you beat the system to the brake you will sense this.
We can feel the lurch of the brakes being applied when a car in front of us turns off the road, even though it’s out of the way in plenty of timer to avoid a collision so I don’t think I buy the assertion that it goes into a coasting mode before deciding to brake. It’s so annoying I’ve gotten into the habit of disengaging cruise control when I see someone activate their turn signal in front of me.
Scared the sh**t out of me the first time it happened! This was on a road trip out west with barely 2,000 miles on. I was going about 75 when the vehicle in front of me turned onto the off ramp, as I approached next to it the brakes came on dropping my speed to about 60. This happened a few more times on the trip and I finally figured out to turn off the cruise when a vehicle exits. Toyota definitely needs to fix this.
2019 Platinum HL
I thought this would be a great feature, but personally like some others have mentioned, I've had vehicles ahead of me go to make a turn and it brakes so hard, I've almost been hit from behind by someone following too close. The thing that bothers me the most is the vehicle that was turning wasn't even a danger or that close to me. I wish I just had a simple cruise control. Here in Indiana, you can get a ticket for driving in the passing lane. But if I dont and I've got my cruise set at 65 and someone ahead of me is going 50mph, then next thing I know, I'm doing 50 as well unless I have a opportunity to change lanes. Like the engine shut off button that has to be pressed every time to disengage it...its really annoying !! ?
2019 Platinum HL
Thank you...I soooooo agree....its as annoying as the stupid engine shut off that I have to press EVERY time I get into the Highlander. Its Ass backwards and should be something I turn on " if " I want to use it. When this feature suddenly brakes the Highlander that fast and hard, it scares my wife to death sitting in the passenger seat. She thinks I hit the brakes without a reason...
So many issues I wish I'd know about, but had no idea during my 10 minute 3 mile test drive I got before deciding to buy it !
While the braking thing on cruise control sounds like a good idea, operationally it sucks. If youre cruise control slows you down because the vehicle in front of you is exiting or turning as soon as that vehicle is out of the picture the cruise control will basically floor it to get back up to speed. I don't use this feature just because of this, id rather have to reset after slowing down, after all its just a flip of the switch. I can't prove it but I also think I get better gas mileage using the nonradar controlled cruise control.
Sent from my VS996 using Tapatalk
Yes - page 293 of the '18 owner's manual.
When constant speed control mode is selected, your vehicle will maintain
a set speed without controlling the vehicle-to-vehicle distance.
Select this mode only when vehicle-to-vehicle distance control mode
does not function correctly due to a dirty radar sensor, etc.
With the cruise control off,
press and hold the “ON-OFF”
button for 1.5 seconds or more.
Immediately after the “ON-OFF”
button is pressed, the radar cruise
control indicator will come on.
Afterwards, it switches to the cruise
control indicator.
Switching to constant speed control
mode is only possible when
operating the lever with the cruise
control off.
Is there a setting on the 2018/2019 HL for non-radar cruise control, other than shutting off cruise control completely?
I can't speak to anything other than my 19 taco. On mine if you just hit the button to turn on cruise control it goes to the radar controlled cruise , however if insted of just hitting that button you press and hold , the display will show just normal cuise control.
I like the way they say only use this when radar system is not functioning. I realize they view this as a safety system/feature, however they are trying to protect us from ourselves. I'm not into all this new fangled stuff, especially the self driving cars. Takes the enjoyment out of driving. I was talking to a guy the other day that said his next car was gonna be a Tesla, that way he could just hit the button and take a nap till he got there. Not me, I like the drive.
It's annoying for sure. What I've been doing to counter it is just apply a little throttle. Give that a shot instead of disengaging and re-engaging all the time.
If one tried to take a nap while driving a current Tesla model, the nap is likely to be permanent.
You don't even have to hit the accelerator hard enough for the engine to catch up with the transmission...... just light pressure is all it takes to disengage the brakes and coast but leave the cruise engaged.
As for it applying the brakes for someone exiting the road.... my 2017 SE is very accurate. if part of the vehicle ahead is still in my lane, it reacts as though the entire vehicle was in my lane. As soon as ALL of the vehicle is out of my lane, it speeds up again. Can't say as I blame it either... the obstacle was real. It just isn't smart enough to know when to violate the preset following distance. I either let it react or just lightly press the accelerator.
Personally, I LOVE radar cruise. Best feature on the car for sure. I HATE having to constantly adjust regular cruise for people ahead of me that slow down or can't maintain a steady speed. If you don't like automatically slowing down for the car in front of you, just pass them?
Paul
That very well could be, I know absolutely nothing about Tesla's other than I'm not interested in them. I know Cadillac has been advertising this feature however in the small print it says only available on certain roads. I don't know if that means the so called hi tec roads with baried cables or only where 5G is available or what.
1 - 20 of 24 Posts
