Can anyone tell me the correct process for changing the automatic transmission fluid on a 2002 Toyota Corolla. I can not see a drain plug so do I have to take the whole pan off? Do I need a new gasket or does it have to be glued back on? If it is glued, how do I remove the pan and what glue do I use to put the pan back on? Is there a filter that needs to be changed?
