1 - 13 of 13 Posts
F
Guest
the digital gauge on my avalon dash says i only have 260 miles left
when its at full tank. i remember when we first had the car back in
2000’ it would say 430miles on the full tank
once in a while it would say 430mi but is only seldom
My friends 02’ avalon still says 420miles on a full tank on her
digital gauge.
is something whent he fuel sending unit on my car? or is something out
of place in the fuel tank?
Posted using the http://www.autoforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.autoforumz.com/Toyota-Avalon-fuel-readings-dead-wrong-fuel-sensor-ftopict120675.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.autoforumz.com/eform.php?p=586608
J
Guest
Discussion Starter #2
My BMW had a similar problem. The fuel level sending unit was dirty. There
has been a reported problem with high sulfer levels in the gas causing the
fuel sending units to go out. This is an old story, and may not be a factor
in youir problem, but the affected refineries were in the southeast
somewhere.
"felixadacatz" <[email protected]> wrote in message
news:[email protected]
> 2000' it would say 430miles on the full tank
> My friends 02' avalon still says 420miles on a full tank on her
> digital gauge.
> Topic URL:
C
Guest
Do you mostly drive your Avalon around town? The miles to
empty is calcualted based on the amount of fuel in the tank
and your recent driving histroy. Assuming you do a lot of
stop and go city driving it is possible that your miles to
empty might really be 260 miles on a full tank. For the cars
I've owned with a "miles to empty" indicator, the miles to
empty can actaully increase as you start driving on a long
highway trip, at least until the moving average mileage used
by the computer to calculate the miles to empty matches the
actual mileage.
Of course, there could be a problem with the tank sensor.
Just comapre the miles to empty reading before and after a
few fill-ups and see if the dleta matches (or least
approximates) the miles actually driven.
Regards,
Ed White
> digital gauge.
F
Guest
Re: Re: Avalon fuel readings dead wrong, is it fuel sensor?
"cewhite3" wrote:
> miles left
> back in
> actual mileage.
> Regards,
> Ed White
> her
> > digital gauge.
> something out
> standards
well the avalon has, avg econ setting, avg mph, and "miles to empty"
setting
i understand the econ and avg miles, but the "miles to empty"
setting it shouldnt vary, default mpg on the avalon is 26mpg. that
means i should have at half a tank around 221 mi left. and full tank
420-440mi. im thinking its the fuel sending unit as spamcatcher said,
hopefully someone with the same problem can direct me in the right
direction
i went to toyota they were going to charge $80/hr to locate the
problem. it means they may take their time "locating".
B
Actually you think wrong, the miles to empty is a calculation
based on the AMPG. Let say you drove in town for the first half
of the tank. The miles to empty now indecated would not hold
true, if you then drove 60 MPH per hour on the interstate, for
the reaming half tank.. The miles to empty would go UP, not stay
the same, based on
the new higher average MPG. ;)
mike hunt
> setting
> direction
J
Guest
Discussion Starter #6
> "cewhite3" wrote:
> > miles left
> > back in
> > actual mileage.
> > Regards,
> > Ed White
> > her
> > > digital gauge.
> > something out
request
> > standards
> > > Topic URL:
> setting
> direction
They are going to replace the fuel lever sending unit. In my BMW, this is
either $150 or $250, give or take a few bucks, for the parts. (I have two
sending units, the expensive one is an integral part of the fuel pump.)
On my car, the needle wouldn't point to F either. When it managed to move
off of E, it gave a correct calculation of the remaining fuel supply, both
the needle and the Distance to Empty display. If you needle goes to F, then
I suggest that the problem with the Distance to Empty is not the sending
unit. Toyota could have gotten fancy with the design, and used a separate
sending unit for the Distance to Empty display.
A
Guest
Discussion Starter #7
In fact Mike is correct for once. If I leave my Avalon set to show miles
per empty, sometimes it will go up if I am driving at a steady speed.
> the same, based on
> mike hunt
>> setting
>> direction
D
Discussion Starter #8
Acutely I'm correct 99.9% of the time, you just don't
know it. LOL
mike hunt
> > the same, based on
> > mike hunt
> >> setting
> >> direction
F
Guest
Discussion Starter #9
> know it. LOL
> mike hunt
> to show miles
> steady speed.
>  > > Actually you think wrong, the miles to empty is a
> calculation
>  > > based on the AMPG. Let say you drove in town for
> the first half
>  > > of the tank. The miles to empty now indecated would
> not hold
>  > > true, if you then drove 60 MPH per hour on the
> interstate, for
>  > > the reaming half tank.. The miles to empty would go
> UP, not stay
>  > > the same, based on
>  > > the new higher average MPG. ;)
>  > > mike hunt
>  > > felixadacatz wrote:
>   > >> well the avalon has, avg econ setting, avg
>   > >> setting
>   > >> i understand the econ and avg miles, but the
> "miles to empty"
>   > >> setting it shouldnt vary, default mpg on the
>   > >> means i should have at half a tank around 221
>   > >> 420-440mi. im thinking its the fuel sending
>   > >> hopefully someone with the same problem can
>   > >> direction
>   > >> i went to toyota they were going to charge
>   > >> problem. it means they may take their time
> "locating".
when does it know when to recalculate the MPG? when i pump?
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.autoforumz.com/eform.php?p=589454
A
Guest
Discussion Starter #10
> > know it. LOL
> > mike hunt
> > to show miles
> > steady speed.
> > calculation
> > the first half
> > not hold
> > interstate, for
> > UP, not stay
> >  > > mike hunt
> >   > >> setting
> > "miles to empty"
> >   > >> direction
> > "locating".
Depends on what model year Avalon. Other brands have a manual reset button
but the 2001 Avalon restart calculating average MPG everytime you start the
car. In other words it zeroes out when the car is turned off. I believe
later Avalons are supposed to zero only when you fill up the tank but that
is just based on postings I've read here.
R
Discussion Starter #11
No it calculates approximately every five minutes of
operation.
mike hunt
R
Discussion Starter #12
I own a 1983 Continental Mark VI Signature. I has nearly 90K on
the clock. I have never reset the AVG MPG since new.
No matter if I drive for three weeks in town or 3,000
on a trip, the average never changes since it has record my
average MPG for 90K. Is shows 23.X Naturally the MTE varies in
those different scenarios ;)
mike hunt
So I just bought a 2020 Avalon Touring. This fuel gauge has to be faulty. I see what Mike Hunt says, but my car topped off says 334 miles to empty. The other day the gas light came on at 23 miles. So I drove til it had 8 miles remaining And the needle wasn’t even touching the empty line. I have the Toyo App for the car, it reads a little more than 1/8 tank difference. Going 50 miles and it shows i burnt a 1/4 tank(no way). Now, when i fill up, I fill at 10 miles left, once it took 12.2 gallons, another 14.2 gals and another 15.8. I’m certain this is an issue?
1 - 13 of 13 Posts
