A half shaft costs less than replacing a CV boot (<$90.00 ea from NAPA re-manufactured) They are not that hard to change.... A local garage can do it. I did it on two different vehicles in less than 1 &1/2 hours each, for both sides.I JUST BOUGHT USED CAMRY 2007 AT CARMAX 3 MONTHS AGO AND NOW MY AXEL HAS OIL LEAKING AND EXHAUST IS PHYSICAL DAMAGED TOO. WHAT COULD I DO NOW ? THE AUTO BODY WANT TO CHARGE ME 4300 USD FOR REPARING (!?) I CANT BELIEVE THAT :headbang:
PLZ HELP ME !!!
Please, take your keyboard off caps lock as it's the internet equivalent of shouting. Forum rules also require that you not use caps lock. Thanks! :thumbsup:I JUST BOUGHT USED CAMRY 2007 AT CARMAX 3 MONTHS AGO AND NOW MY AXEL HAS OIL LEAKING AND EXHAUST IS PHYSICAL DAMAGED TOO. WHAT COULD I DO NOW ? THE AUTO BODY WANT TO CHARGE ME 4300 USD FOR REPARING (!?) I CANT BELIEVE THAT :headbang:
PLZ HELP ME !!!
I was not driving at that time, my friend did cause i was so tired just out from work at midnight. SHe tried to slow down instantly when see that terrible thing but i really have no idea why it appears on the freeway.Now that I have more details, it is the drivers duty to prevent accidents/damage.....
If the parts are OEM, they might be in line (cost). Check with the supporting venders on this site, for pricing.....
as far as the axle not leaking any more this makes perfect sense as now all the oil is gone and soon enough, you will lose your axle.........as for the exhaust pipe, you are probably hearing a whistling or hissing sound. have a garage, preferably a muffler shop weld up the big dent and seams in the pipe and be done with it...........this is all that happens (and more) when you let someone else drive your car at high speeds...........and have an accident.My axel now stop leaking oil (that's great idk why), but the exhause pipe as u can see is horrible physical damage, why i run low speed there is strange noise from there. Should i replace new one or leave it like that! plz help me cause i dont have much money
Uploaded with ImageShack.us
