1 - 7 of 7 Posts
Honda Civic
mine is a 4cyl 5spd. 3sfe. middle piece on passenger side (2 piece) nuts/bolts flew off?...i was wondering of my other choices.. probably an oem upgrade? something like celica or v6 camry axles (2nd and 3rd gen)? if not, will 4cyl auto axles work? i would perfer something alittle stronger this time. axles been going out once in a while on this 5spd 4cyl.
Honda Civic
Discussion Starter · #3 ·
fredk said:
they just flew off huh?
yes.. i jus pulled it apart. the piece that connects to the hub is no good. somehow the part that the bolts hold towards to the second piece to the tranny is broken. one bolt with stud left.
· NYR
Your axles shouldnt be wearing out so fast, perhaps you have another problem that's causing them to wear out prematurely.
Ive never had an issue with the axles on either one of my 5 speeds in that respect.
And you can only use the part that is specificaly designed for your model
· Bullitprooph
1986 MR-2 N/A, 1991 Celica GT-S, 2005 Matrix XR, 2009 Matrix XRS, 2009 Matrix Base
Whoever replaced the driveaxle last time did NOT torque those bolts onto the half-shaft properly. I replaced the one on my Camry almost five years ago and they've never loosened off a bit.
As for your constant driveaxle problems: are you using white-box reman parts, or used parts from the scrap yard?
Honda Civic
Discussion Starter · #7 ·
yes it looks like they didnt torque the bolts down. it also damage the axle when it fell off.
just to let everyone know, celica uses same axles. i pulled off a celica st axle and bolts right up.
1 - 7 of 7 Posts
