1 - 3 of 3 Posts
The back-up lights on my 2001 V-6 5sp Tundra no longer work.
No power to the bulbs, and all fuses I can find seem OK.
Manual does not specify which fuse is for BU lights...
Wonder if the problem is in the trans switch, and if I have any hope of repairing this myself???
Thanks!
SD
Looking at a fuse is a waste of time, use a test light or volt meter to check fuses, they can have small breaks that you can't see. Does your truck have the factory tow package? & factory trailer wires?
Your rev lights use the gauge fuse, the remote mirrors also use that fuse, so if you have gauges, hopefully their is power at the rev switch. I'd turn the key all the way to the on postion, but don't start engine, crawl under truck with a test light or volt meter, unplug rev light switch & check for power coming out of the blue/yel wire, the red /blk wire goes from there to a plug under driver seat then out to rev lights. hope this helps. let my know if any trailer wiring was ever done. Darrin
1 - 3 of 3 Posts
About this Discussion
2 Participants
burned300
Toyota Nation Forum
Full Forum Listing
