1 - 5 of 5 Posts
As stated, backup camera quit working a while back. I pulled the console to check wire connections and when I put the car in reverse I'm not getting any voltage on the power wire. Any ideas what the issue could be? I don't see any backup camera settings on the HU (factory).
Thanks!
If it is OEM, have you looked at a wiring diagram?
It is "OEM style", ordered from Amazon I think back in 2015. I installed it so I'm familiar with the wiring. Thought I read on here somewhere that something around the shifter gets worn and quits making contact but can't find it now.
I don't know how it is wired so I am not sure. If it is not getting power, find out why it is not getting power. If you know where you connected it on the wiring harness, a wiring diagram should be able to show you why you are not getting signal. Or you can try to power on the camera straight from the battery to confirm if it is camera that is getting issues or just signal.
1 - 5 of 5 Posts
