1 - 4 of 4 Posts
Hi, where and how do I determine where if any fuses are located for the backup lights on a 1998 Tacoma?. Can not find it in the under hood fuse block. Could a devise be located at the transmission=automatic. Thanks
1995 T100 2WD
There should be a 10a fuse marked "gauge" in the fuse box in the cab, driver's side kick panel as well as the switch on the side of the transmission. Working from memory but worth a look.
1995 T100 2WD
I do not see or find a fuse box inside the cab at the kick panel .If on the transmission what would it look like? Thank you very very much. Jim
Engine compartment fuse box , fuse #20 Gauge, location should be in or on the fuse box top. Pages 239-241
1 - 4 of 4 Posts
