Yeah, and it's a pain to switch it out - Serious PITA. It requires dis-mounting the fuse box, wrestling the wire tubing to try to semi-invert it to gain access, and then removing 2 x 10mm nuts securing it that have zero clearance and near-zero throw angles to loosen the nut. It's only a $4 part, but it's $80 of labor to change.
If you are in this position, take your time and work slowly. Also, never get in this position and remove your battery leads if messing with the alternator or any time the FSM calls for it.
Here's the chant I use to remember how to jump start a car w/o doing this damage:
Doing CPR on a car:
Dead CAR, dead POST, dead REACH.
So that means on the car with bad battery (dead car), take the lead to the dead post (e.g., negative/ground), and REACH it to another ground besides the post.
E.g, ground the dead cars negative lead to earth - frame, engine, etc. Then you can never blow a battery (I have seen this screwed up and the battery explode and spray acid), blow an alternator diode pack, or blow a main bus fuse.
Hope my late night long-winded rant saves someone some pain down the road!
Cheers and another rum and ginger drink for me...
