I have a 2019 Hybrid Limited Plat. When it's cold and I need the heater I've noticed it takes a little longer than all my other cars (including a 2008 Highlander Sport). It will usually take a good 10 mins before it starts blowing hot air. When it does, it's all good. When it happened the first few times, I actually thought something was wrong with the heater until it finally kicked in.
Fast forward to this week and the ice storm here in Texas where I live. After spending 3 days locked up in the house, I decided to venture out and cruise around my neighborhood to see how bad the ice was. It was 28 degrees outside and I slid around the neighborhood for 30 mins (gotta test the AWD every once in awhile).
What was concerning was that my heater never started blowing warm air. Keep in mind in my driving around, I never went over 30mph and half the time, I was riding my brakes as I creeped around. Most of the time, other than punching the gas to spin the tires here and there, I was in battery/EQ mode. The temp gauge was in it's normal location (halfway between C and H) within 5 mins. My car is garaged at all times, so it wasn't sitting outside coated in ice or anything. After 30 mins of cold air blowing, I decided to take it outside the neighborhood and drive it faster. I went on one stretch of less icy road about 3/4 mile long and got it up 45mph. Then it started blowing warm air. However, at the stop sign, I needed to turn down a different road that was very icy, so was back to creeping along at 25mph and alas, back to it blowing cold air. 1 mile later, I was able to turn down a different road back towards my house with less ice and again, got up to 45 and it started blowing hot air...and yet again, when I slowed down to turn back into my neighborhood and creep along, cold air came out.
I'm dumbfounded by this. I had the temp on high, and switched around between vents (both floor and face vents) along with defrost. Even with defrost on, my windshield started to get iced up due to it blowing cold air. I feel if I was stuck on a highway going 20 mph for 20 miles, I'd freeze to death. I'm sure we have all done the start the car and sit in it while it warms up/defrosts, but that doesn't seem possible in this car. Is this a huge design flaw where the heater doesn't kick in unless you are driving at a speed where the engine is running generally on gas? I feel like the problem is that I was mostly running on battery when I driving and recharging the battery while riding the brakes and thus, the heater doesn't kick in. But that seems like a pretty bad design. What am I missing?
