Bad idle
1820 Views 2 Replies 3 Participants Last post by  shaffer
I have a 95 S/C. Now when I start it, the van shakes, and it idles low. After about 15 seconds, it runs normal. I don't know if the recent cold temperatures are partially to blame, or if there is a problem, or if it just happens. Anyone else have this problem and know what the real problem is?
1 - 3 of 3 Posts
check and change spark plugs, ignition wires, air filter. if that doesnt help start looking around the cold start injector.
bad idle
:thumbup: I have had this problem..with a few of these vans too...also the old vanwagon...it has to do with the fuel pump...and filter..a royal pain to remove and replace..it's in the tank...basically..it'll make more and more noise and shake..untill it fails...the fuel pump is getting itself up to pressure...thus..a shake and a noise...
1 - 3 of 3 Posts
