Ok so I thought this would never happen to me, but I managed to F this one up big time.
An oil leak problem had really gotten bad and I ran the car on low to no oil for many thousands of miles. The final push to total mechanical failure happened when I made a long trip from NJ to Maryland and back, during July 4th weekend. A few days after I got back, a bad clank/slap sound developed and the engine shut off at a red light. I checked the oil stick and it was nothing, I knew I had totally f'ed this up.
Well a friend of mine stopped by to check it out, we tried to run a compression test, but didn't have the tool to remove the spark plugs, but he said that if the engine is at least running, as in, the crank can turn, its not completely seized, and may be repairable, depending on if its worth it or not. He said the engine would at least need a new head to start off with, but with the other parts in the engine, we won't know the full extent of the damage until we actually open it up. Like he mentioned some pretty bad piston slap, as what it sounds like. The car barely moves, it will shut off in 2nd gear.
Would anyone know a ballpark figure for how much an engine swap w/ another 5sfe would be?
If not, would it even be worth taking the engine apart and fixing all the problems? I mean if the car is gonna be junked, I mind as well attempt to open it. After running the car on no oil in the summer, I am still surprised that it didn't seize up on me, keep in mind July 4th weekend was one of the hottest weekends on record, I mean hell, the whole month was the hottest on record around the world. At least my radiator is topped off and the engine temps were fine.
