i did a rebuild on my tercel since it was knocking, it turned out to be a spun bering on cylinder 3.
Rebuild on a 3ee. Head job at local machine shop valves and springs but reusing previous rocker arms and camshaft, cold lash set to .007.
Crank and pistons w/rods reground and inspected by machine shop. New rings/bearings with plastigauge(all with in spec though i dont remember the numbers). new water pump, clutch, belts, idlers.
everything was tightened to torque
i took out the spark plugs and turned the key to get the oil pumping through the system then checked and had oil in the oil filter. spark plugs back in and it didn't start! Turned out the distributer was in backwards so that fixed it started right up and no low oil pressure light.
http://youtu.be/hpqFJ7oBsCY
it is leaking oil out of the front of the valve cover
so what is this sound? i have only had it started for a short amount of time and have not driven it, i am most worried about the rattle on acceleration
The ac belt is not connected, though i don't see that would make a difference
