2005 Corolla CE 1.8.
Overheated to the point of blowing off the upper radiator hose.
(Daughter is not always very attentive to things like temperature gauges)
DTC was set for the Coolant Temp Sensor- I tested it, failed it and replaced it.
Replaced thermostat, even though it seemed fine, and even though the frakking alternator has to be removed to get to it.
Water pump had been replaced less than a year ago, and it's a PIA, so ignored it.
Put it all back together, burped out the system and called it good.
Two days later girl calls and says it is overheating again.
Overflow tank was normal, and no coolant loss was evident, and no DTC.
I drove it around a bit and could not get it to misbehave at all.
Double checked the cooling fan operation and the CTS- all fine.
Next day she calls back- overheating almost to redline, and no heat.
I started it up cold and let it sit until the fan came on, and then some- no heat in the cabin.
Upper radiator hose HOT, lower hose COLD. Okay- water pump. Pulled pump, fine- no detached impeller or other discernible defect. Scratched head, removed hoses and inspected for delamination- still almost as new as when I put them on less than a year ago.
Did some checking, and the water pump literature states that it turns counterclockwise- and it does.
In looking at it, it appears the vanes are set for clockwise rotation, but so are all three of the other pumps I looked at from different manufacturers.
Removed thermostat, gutted it and reinstalled so that there would be no question of it being stuck.
Put it all back together and ran it until the fan finally came on. Upper and lower hoses both hot, and good heat inside.
WTF? Anybody?
WTF? Anybody?
