1 - 5 of 5 Posts
Discussion Starter #2 (Edited)
Baja Rack "The Mule" installed on Jacque's 3rd Gen 4 Runner, mounts straight to the factory roof rack. Optional shovel and axe holder on passenger side. This would be a good fit on just about any Toyota with a factory roof rack.
Specs:The mule rack was designed as a rugged aerodynamic gear basket. It's lightweight and comes with an aluminum wind deflector. It mounts to most shapes of factory racks, including Yakima's and Thule's crossbars, and Toyota's cargo crossbars for the bed of the 2005-2009 Tacoma. You must have the above listed roof racks, or factory roof rack to mount this on.
Measures 48" long, by 39" wide, and is 7.25" tall. Weighs 38 lbs.
FJC Expedition Rack
Description: FJ Baja Rack - color is black, measurements 48" wide, by 84" long, and 6 " tall, HAS FLAT AREA FOR ROOF TOP TENT, area measures 48" wide x 58.25" long. This rack comes in 3 parts, ships in 1 box, assembly required.
It is made of 1" carbon steel tubing, aluminum wind deflector, (with clear finish over the powder coating for easy clean up and extra protection), floor tubing mesh tingly spaced so small items dont fall, installs directly to teh factory mounts on the roof, all mounting hardware is stainless steel, its design allow for the contours of the fj roof while keeping the bottom level, load capacity 300 lbs, total height of the vehilc with the rack installed is 78.25" with stock suspension and wheels/tires, rack weight 52 lbs. GEAR, TENT, RED CANS AND CAN HOLDER IS NOT INCLUDED.
Good selection in stock! Email with ToyotaNation in the subject line for current pricing.
New products coming out shortly. FJ80, 3rd and 4th Gen 4Runner and a larger expedition rack for the FJ Cruiser. We'll have pictures up as soon as possible.
Thanks,
Gerone
1 - 5 of 5 Posts
