1 - 7 of 7 Posts
03 Camry & 06 Sienna
2006 Sienna LE
I think my alternator is dead. Read the following thread to see how I got here:
http://www.toyotanation.com/forum/showthread.php?t=291523
So my battery died the other day after 2 days of battery light. I'm sure the alternator did not like having rust-laden water/antifreeze sprayed all over it. The question now is, can the alt be saved? Can I open it up and clean it out with some good elec cleaning spray? Can I just replace the brushes? Has anyone seen this problem before?
Does anyone have a DIY for alt rebuilds? The one on this forum has lost all its pix.
:headbang:
I HAS BOOST!!!
94 Camry SE V6 Coup
it really woundt be worth a rebuild, you can get reman ones for fairly cheap using your old one as a core. id say yes to trying to clean it with an electrical spray for the hell of it. have you replaced the battery?
2006 Sienna LE
What's cheap?
That was my first thought too. But I'm finding remanufactured alts for >$100 and used ones from junk dealers between $30-$60.
Some of the used ones look pretty scary!
And no, I have not replaced the batt. I put my 15A charger on it and ran it overnight. Indicator showed 100% in the morning, so I think its okay.
G
Its more common for the voltage regulator to fail than the brushes or windings. Just go with a rebuilt one. Getting a junkyard alternator may give you the same problem in the near future. If you really want to re-build the one you have, look around in your local yellow pages for a starter/alternator rebuilder. I had my paseo alternator re-built for about the same price as a brand new one ($130) but they replaced everything and even re-painted it.
"look around in your local yellow pages for a starter/alternator rebuilder"
I have to agree with 96paseo. This was going to be my advice too. I have found that the local electrical rebuild shops do a better job than the mass rebuilders that do the rebuilds for auto parts stores IMHO.
As far as the battery, I wouldn't buy a new one just yet, especially if it is not that old. Try recharging it from an outside source at a slow charge, say 1-2 amps. It may be fine after that.
Mike
2006 Sienna LE
Discussion Starter · #7 ·
Problem solved.
So I went to Checker and bought an Autolight reman for $137 w/ lifetime warranty. All is well and both the tail light indicator and the batt light are out. Any ideas why they would BOTH have been on? As I indicated, no issues with tail lights. Maybe there was a short?
1 - 7 of 7 Posts
