I had not thought about that. The only problem I have with T100s is the limited availability of aftermarket stuff. I'm not sure a bedliner is still avalable. These trucks were produced from '93 till '01, but in fairly limited numbers, partially due to the import truck tax our government placed on them, so they aren't around in huge numbers like Fords and Chevys. However, I sort of like the exclusivity since you don't see them on every corner.Have you looked into finding an under the rail bedliner?![]()
Check car-part.com They have a few sometimes. I would just cut the liner if it were me. Use a dremel or razor knife and measure carefully, and it should look just fine if the cuts are close and straight.I had not thought about that. The only problem I have with T100s is the limited availability of aftermarket stuff. I'm not sure a bedliner is still avalable. These trucks were produced from '93 till '01, but in fairly limited numbers, partially due to the import truck tax our government placed on them, so they aren't around in huge numbers like Fords and Chevys. However, I sort of like the exclusivity since you don't see them on every corner.
By the way there was not one single spec of rust on the bed of my 15 year-old truck.
http://www.toyotanation.com/forum/showthread.php?t=207691I'd post a picture if I knew how.
