Ok, don't laugh at my idea. I've been debating which bed liner would be best for me and I can't think of the right one. How's this idea...duraliner and cut out the bottom, and a fitted rubber mat to replace the bottom that was cut out? I have some holes that I can screw the duraliner to the bed to secure it. So the duraliner provide protection to the wheel well and sides, and the rubber mat protect the bottom.
Here's my analysis of the different liners available:
- Duraliner = best protection but create scratches underneath that can/will lead to rust. I will not be deligent enough to remove periodically to clean underneath and slight PITA to remove.
- Spray-on liner = too expensive and not as good protection like duraliner
- Bed rug = like it the most but too expensive
- Rubber mat = pretty inexpensive but no side wall/wheel well protection and easy to remove to clean underneath.
My usage for my truck is light but I want to be prepared for heavy usage. My truck body is decent so I'm having a hard time justifying spending say 400+ on spray on type or close to 400 for the bedrug. Remember, I'm in Hawaii, things are not cheap. I'm estimating I'd spend between 150 - 175 for my hybrid setup. Used duraliner and new rubber mat.
What do you think?
Thanks for reading.
'89 2wd std cab 22R
What do you think?
Thanks for reading.
'89 2wd std cab 22R
