re: 93 previa all trac 330k miles engine replacement:
replacement engine removed from donor van with trans attached.
forgot to remove flex plate/torque conv bolts.
moved trans about 1.5" away from engine before relaizing my mistake.
could I have bent the flex plate?
In case I replace, anyone know the flex plate to crank bolt torque spec?
93 2wd and 93 all trac: same ECU brain or different?
How to lift replacement engine into van?
hoist from above or lift from below?
Thanks.
Thanks.
