G
Guest
·Autotree Pro Ver. 1.45 is a 32 Bit ( WIN95-XP) software Application for
automotive diagnostics. The program written in a Tree format to make
systematic and quick diagnostic checks a breeze, organized by area
(Engine, Transmission, Electrical, Fuel, Emission, body, Clutch, Etc. )
Just click on the area of interest, then the problem and get instant
repair suggestions to all your problems, covers all the major areas of
car repair. (Engine, Fuel, Ignition, Emission, Drive train,
Transmission, Brakes, Clutch, Body, Interior, maintenance, Etc.) THIS
PROGRAM HAS WELL OVER 600 GENERAL REPAIR SUGGESTIONS THAT APPLY TO ALL
VEHICLES FOR OVER 100 SYMPTOMS. Great for Repair Shops and the Average
Buyer as well. Buyers get free upgrades.
Program may be downloaded after purchase. (Paypal)
Also includes an exstensive 50,000 error code database for all
computer controlled systems, Powertrain Control Module (PCM) Codes
(Engine/Transmission), Engine Control Module (ECM) Codes* Powertrain
(P) Trouble Codes, Instrument Panel Cluster (IPC) Codes , Antilock
Brake System (ABS) Codes , Supplemental Inflatable Restraint (SIR)
Codes , Air Conditioning Programer (ACP) Codes, Traction Control System
(TCS) Codes , Body Control Module (BCM) Codes, and Road Sensing
Suspension (RSS) Codes
In addition to a fast easy to use treelike structure, any section
that requires such will refer you to a notes section for a more
detailed description of what to look for and how to fix it (Scroll able
text boxes). The software also has many new engine emission checks (
How to read Engine CPU/ECU LED error codes which make complex
electrical and emission problems easy to understand and detect which
component has failed, ( Ford, Chrysler, GM codes ).
Many of the other Options it has include a repair Database (for note
taking during repairs), A Mileage Calculator and record keeper (12
month), with charting Graphs (to compare mileage (before/after tune ups
or to watch for the need of a tune up)), or to track tire wear, blue
book value changes or anything else you might want to use it for. A
Maintenance Database for the date/Milage of the Last tune-up, oil
change, Trans service, New Tires, Brake Work, Hose/Belt Inspection,
Diff. Service., wheel bearing pack, Cooling system Service and more.
Plus Popup Scroll Text Boxes for : Notes (Extended or Complex Repair
Info.), Another sections tells what Spares to Carry on long Trips, how
to buy a good used car, and abbreviations used in the software. A year
charting function to chart any values that change by year (Car
depreciation, tire wear, etc.) And much more. Program also has pulldown
menus with Emission codes for ECU/CPU checking for Ford, Chrysler and
GM.
Written by a Programmer that was a journeymen mechanic himself for
over 15 years (myself, With lots of on the job tricks of the trade
understood). This program gets right to the point and does it fast with
a very easy to understand interface. Buyers may also Email me (Email
Form built into the application) for any non covered problems they have
and I research it ( I have around 30 chilton manuals for such) and
answer you right away as well as include this additional info in the
next upgrade release provided FREE.
Keyword list (Title) : car auto vehicle repair fix truck engine motor
cd software program application
Best Title :Auto Repair car vehicle CD Software
website at www.vehiclerepair.org
GM.
