1 - 4 of 4 Posts
05 TRD Sport Tacoma
Don't the 6 inch kits come with new shocks? All the way around in fact. Aside from that I think the consensus is that the Fabtech 6inch kit is superior to procomp...although I don't know for sure. I'm fairly certain fabtech kit comes with everything you need...hopefully Toku will help you out...but a quick search should yield you all the information you need
· 2012/14 Stanley Cup Champ
A lot of people rave about how good the BilStein 5100's are.....just order an extended length shock from them. You will need to know the full extension and collapsed lengths and then you should be good.
· Toyotanation
If you're going with the stage II kit it already comes with a set of Coil overs, and rear shocks.
If you are asking because you are doing the stage I basic kit? Then the DR coilovers are a good choice.
But because you are doing a 6" lift. It is better that your suspension is a bit on the stiff side, because you center of gravity will be higher.
1 - 4 of 4 Posts
