It is now apparent that my 1997 V-6 Camry has leaking valve cover gaskets, especially the rear one. So, I will most likely tear into it this weekend and replace them both. Before doing so, I have a few questions. First, is the standard FelPro rubber gasket from a local auto parts store okay, or is it best to get a Toyota one? I've read the posts about using RTV, but I'm more predisposed to using what was designed for the task, so I'll most likely be putting a gasket back in. Second, will the valve covers come off without removing any of the timing belt covers? I would assume so, but wanted to make certain before starting. I'm hoping all that I really need to do is remove the upper intake to be able to access the rear valve cover. Finally, are there any other problem areas I should check on the rear of the engine while the upper intake is off? I recently replaced the spark plugs with new OE plugs so they should be fine. Any additional info regarding the valve cover gasket change would be appreciated.
Regards,
Robert K
Regards,
Robert K
