Hi,
I currently drive a prius and recently had to replace the water pump, i then couldn't fully bleed the coolant as the prius has fancy electronics and had to bring it in to the dealer. Long story short they failed to bleed the air out off the coolant properly and told they would have to diagnose the issue. Meaning that i could be liable for a huge diagnostic fee or could not. I was able to bleed all the air out after following the correct procedure something a toyota master tech should have done. Once the air was out the coolant level dropped a bit due to no more air pockets.
My dilemma is that i paid money for the stealership to do the job and they didn't do it. I can easily fill up the coolant and top it off and not go back to them. However i'm upset that the dealer did not do it right in the first place. They should have taken it back and re-bled the coolant properly and then mentioned diagnosing it, or something like that. I am currently in school so when i spend money i make sure its worth it. So what is the best way to handle this? Do i go back and get upset, do i just leave it? Any advice would be appreciated.
