1 - 20 of 22 Posts
· Gearhead
Completely up to you - personally, not a fan of those types of lamps.
Those look like regular incandescent bulbs that run at a different color temperature. Gives you that HID "look" with regular plug and play bulbs. Drawback with messing with the color temperature - especially in cases where the bulb is heavily tinted - is that you actually have less light output. Some offset this by running a higher wattage bulb - but then you risk overloading the electricals (possibility of burning out the wiring harness to the bulbs, putting a heavy drain on the electrical system).
Not a big fan of any bulbs off of Ebay - been burned once by that before. I've had good luck with Osram/Sylvania bulbs - same wattage as stock, clear glass, different color temperature (cooler - 4500K to 5000K). Lifespan is about the same as well - they will eventually dim down, but not too bad. Some of the cheaper bulbs will dim significantly over time. High wattage bulbs have bad rep to literally blow up in the housing - making for a messy clean up.
I personally like the color temp slightly shifted toward the blue side of the color spectrum, but not looking blue - this, to me, gives off a "whiter" light with only a slight drop in overall power output, compared to the typical 3800K-4200K color temp OEM bulbs.
But since your eyes are generally more sensitive to a yellowish/green/very slightly blue color temperature - everything looks clearer and brighter than OEM lamps which have a higher red color content. But everyone is a little different - some like it closer to natural lighting (slightly yellow), some like it in the way in the deep blue/purple range.
How many watts does the Corolla 2001 S supply to the ights... if they have a clear bulb shouldn't it be brighter then?
If you can give me a reliable source which I can order Sylvania bulbs I would appreciate it... eBay Sylvania sellers are overpricing their products.
Also, for the fog lights, are these the correct bulbs?:
http://www.ebay.ca/itm/H3-100W-x2-p...ps=63&clkid=8461756478844091436#ht_3937wt_952
· Mr. Roo
Super Moderator
All of those bulbs are complete junk! Including the Sylvania ones. They are overpriced, and any increase in brightness translates to WAY shorter life.
The stock bulbs are 55/65 watts, so going with 100 watts is double and will melt your wiring over time. Stay away!
The ONLY halogen upgrade is HIR technology. It is really easy to find information, and you can get them for around $60 a pair. Made by Philips these days. They are brighter and whiter than regular halogen. You can put 9012 bulbs in the low beams and 9011 in the highs. The fogs take H3 bulbs, but there is no HIR for that. Just leave the fogs alone, they aren't meant to be regular driving lights.
Discussion Starter · #5 ·
I want the fogs yellow, so I need some sort of a replacement. I figured the HID look replacements are out of the question, instead I think I might go with Sylvania (they're already 60$, priced similarly to the HIR).
I've used the Philips X-treme bulbs before. Waay better than Silverstars and last longer too.
They have 2 new bulbs which are suppose to be better and brighter which are the Crystal and
Diamond vision bulbs. You can't get them in the U.S. unless someone imports them and sells
them online. I've ordered them from this website and it takes about a week or so to get them.
http://www.autolamps-online.com/categories/Car-Headlamps/Search-by-Lamp/9006/
Go with PIAAS night tech light. I have tried everything and noting compares to these. I also have a thread on the t100 fourm under red diamond with the lights on low beam with night tech installed. I am amazed with these lights.
2002 Corolla S
Do the hir 9011/9012 bulbs run hotter? I have them in my 02 and the housing where the tip of the bulb sits has changed colors. I dont know if this has been this way prior to the original bulbs as it was never a concern.
· Gearhead
By design - HIR bulbs run hotter than standard halogen bulbs. HIR use a spherical bulb shape and special internal coating to focus some of that energy back toward the filament. By reflecting that energy back toward the filament, they can heat it up to a higher temperature than normally possible - emulating the light you typically get from a thinner filament.
That's why bulbs, like Silverstars and others, burn out so quickly. Thinner filament, burns brighter and hotter - releasing more photons. Halogen gas is used to limit impurities that will cause the filament to prematurely burn out - but eventually it will break.
Some claim it can run cooler - buy feeling the housing temperature - though that is not 100% conclusive. You can almost always tell by looking at the shielding (metal cutoff part) that sits directly infront of the bulb - that tends to turn a rainbow of colors over time. Even some regular halogens can discolor the shield - depends on shape and depth of the bulb.
No worries - it is perfectly normal. I'd only start getting concerned if the HIR bulb blows up. Halogens just die - my experience with HIR, is they tend to blow up and pepper the inside of your lamp assembly, making quite the mess.
Probably part of the reason they were quickly replaced in older OEM apps (ex Lincolns, larger domestics). But are starting to make a comeback after some new designs were put out there. No more special sputtered coatings, multi-axis focusing, lower temperatures, better bulb/filament physical support, extended lifespans, etc. Looking like they will quickly become the new standard "halogen" bulbs - to compete with current HID and LED options out there.
Reactions: Steve40th
· Gearhead
Depends on which ones you have, hard to tell from behind the shield. The Toshiba HIR are no longer in production - whatever they had left, they were selling for some time. The newer ones are from Philips - sort of looks like a cross between a HID and high output residential halogen torchieres bulbs.
New ones look like this:
Since you got the other HIRs in there for 2 years, they are probably getting pretty close to EOL. Most of the good ones, were only designed for 600+ hours of use, before they drop below 70% of original light output. The knock-offs - typically lasted only a couple of hundred of hours before they blew up. On the newer ones, light output is spec'd to be even brighter than the much touted Toshiba HIR bulbs (something like 10%+ brighter). Lifespans are spec'd to be 1400.
Not to fault of the HIR bulb design - just physics. Capturing and redirecting the normal IR radiation that would normally be leaving the bulb, to heat the filament even more - coupled with the limited surface area and contact points to help dissipate the heat generated by such a bulb - once it finds a default in the quartz housing = boom.
1 - 20 of 22 Posts
