So, I have been doing quite a bit of work on my 97 T100, SR5 Extended cab with the 3.4L V6. It is the 2WD model and the front end is sitting about 2" lower than the rear. I recently replaced my shocks, sway bar bushings, and sway bar link ends and this made a huge difference in the ride. I also replaced all of my belts (including the timing belt and H20 pump) and now the truck runs more like new, which says a lot as it has 165K miles on it. I also recharged the A/C and made the AC mod (heat shield and insulation) and this made a big difference in the A/C performance. I would say that I got about 5-7 degrees lower on the cold air side. All of the above I was only able to do due to the pictures that were posted on this forum (Thank you!!!).
There are a few things that I want to do, most importantly go to bigger rims / tires and also level up the front and rear (which should also give me more room for the tires)... Currently the truck has P235/75 15's on it and I have about 3 - 3.5" clearance in the wheel wells (all around). The rear has about 6" clearance (in height) but I would still be limited to the 3.5" on the side clearances.
I am guessing (from reading other posts) that I will need to install a lift kit (or rather ball joint spacers 1.5")... So I have a couple of questions.
If I were to go with the ball joint spacers would I also need to adjust the torsion bars? I am assuming so to get the lift that I am looking for (about 2") to match the rear. Does anyone have any pictures of the torsion bar and adjustments? I have been using the pics on the forum to do most of my work.
What size rims / tires could I fit on the truck (without having to worry about rubbing / problems)? I am guessing that I could only go to 16" rims (and not 17") as they would require a low profile tire... which I really don't want to do... although I am open to it.
Thanks in advance,
Marc
Thanks in advance,
Marc
