The only thing I can think of is a problem with the 'door' inside the box which directs the air. Yours is probably moved by a cable from the control panel. If you pull the glove box you should be able to get a better look at the top of the box. (If you can't see it as is) If that's not it then I'm out of ideas. Good luck!
