WTF? Isn't just the sides the same as your first question?cam98hi said:
edit: anyone shaved their door handles before and know the prices, or the sides?
I was planning to do that but is there enough housing on the camry, so that once it's done- the lamps still work correctly?jackbutt said:You can paint them yourself. No need to buy 'em, however there are some on ebay.com. Take out the headlights from the car and then put them in the oven and you'll be able to take off the plastic lens and paint the reflector housing.
meaning if I did the housings it wouldn't turn out correctly because the lamps would be blocked with the housing and no light would be able to come though?itzsteven said:No! Your lights can't be reflect and you won't able to see anything. Unless you swap projectors in there.
Hm....For some reason when i thought about this, 400 popped into my head immediatly. Then upon further thinking i wrote the 1000 so i wouldn't sound like a dumbass if i was too low. :lol:lepracon9 said:400-1000 for a shaved door handle kit? nooooo way. u can get a spal kit w/ 35lb. solonoids for around $130 on ebay. auto loc kits are higher but not $400.
Yes. If your headlights were 00-01 then you can buy the aftermarket with the black housing. (even thought they're not really black housing)cam98hi said:meaning if I did the housings it wouldn't turn out correctly because the lamps would be blocked with the housing and no light would be able to come though?
