1990 ae92 4afe fuel injected 63,500 miles (brother-in-law original owner) asking $1,700. I took to our look mechanic who said has moderate engine wear based on excessive crankcase pressure because of worn rings and needs valve cover gasket. The top of engine has coating of oil on it (before mechanic). Mechanic tested by removing oil cap with engine running and noted positive ventilation.
Research on this site learned this can be characteristic of overhead cams. My '05 Ranger does the same when the oil cap is removed.
To further check the positive pressure I put clear plastic wrap over the oil filler hole and the pressure is both negative and positive. I then put the cap on and used the plastic over the dip stick tube. Nothing there except a very slight negative pressure. The same with the pvc hose to the intake. The pvc rattles and seems to work fine.
What are your thoughts?
I am planning tomorrow to go to a buddy's forensic science business (where they test all kinds of mechanical stuff) and they will send off an oil sample from the crankcase for analysis that will tell if the engine is bad due to chemical contamination or metal bits.
Thanks... KC
Thanks... KC
