[solved] Blower Motor Stuck On High
2009 Toyota Corolla, Manual HVAC. What would cause the blower motor to be stuck on high? It does not matter if I turn the fan speed knob to 0,1,2,3, or 4, it will not change speeds or shut off. I replaced the blower motor resistor, but that did not resolve the issue. AC/Heat still seems to work fine, just the fan can never be changed. This only runs when the car is on (I have seen several posts where this happens even when the car is off). I have read in for some it could be a relay that is fused together, but have no idea where this relay is located. Any ideas? Thanks in advance.
