I have a 1996 Camry LE that continues to blow the fuse that controls the power windows and the door locks. Not sure where the problem is coming from, but are there any suggestions of where I should start looking? I have always had problems with the right side window (goes up in increments) and the lock on the right side back door doesn't work.
Should I check each area for wiring problems? Is there any other way to check without dismantling the doors?
Thanks
Nug
Thanks
Nug
