Hey guys, finally got done with the retro a couple nights ago. Started at noon and finished at 4 am. Took a lot of breaks lol.
I ended up only using tools and no extra materials. I bought a 12"x18" sheet of 16 g metal plate that I was going to make a bracket with, 36" threaded rod, and nuts/washers. I ended up using NONE of it.
I just took the plastic pieces that screw onto the adjustment threads and put them on the new projectors. I had to cut the middle black piece to accommodate the 3" lens opposed to the 2.5" it came with. I like the cutoff, it is just as good as the eBay ones. But, the output on the ground is much better. I can only expect better when I get OEM D2S capsules.
Okay, here are the pics!
Had to run these things for a day :headbang:
eBay projectors
The new BMW projectors!
Compare new with old
Ended up not using the shrouds... I let my friend have them. Only to find out they go for $80 on eBay :headbang:
Had to remove the solenoid to fit
Testin the new BMW projectors
Mounted
Andddddd the money shots!
eBay projectors
Mounted
