I was replacing my Alternator and forgot to disconnect the neg bat terminal.
Bonehead mistake for sure.
Anyway, was jostling new unit into place and heard buzzing and jerked it away from the area.
Only THEN did I disconnected the neg bat cable. Great.
So installed Alternator, fired up car with a multi meter attached to see if my charging circuit was working again.
Nope, just battery voltage.
Also, now most interior electronics are dead. Radio, clock, heater controls, power windows, turn signals, taillights,etc.
I checked all fuses with the multimeter in the engine bay and under the steering wheel, and they were all good.
Car starts, headlights and fogs work, done light, hazard lights work horn works.
Do you think I blew the main fuse 100a which I cannot figure out how to check.
Or if anyone has any ideas.
I’m going to get tha Alternator checked also at the auto parts place.
Thanks.
Thanks.
