1 - 15 of 15 Posts
Both key fobs for opening doors on my 2005 Avalon stopped working at the same time. Trunk lid opener and alarm also do not work. Replaced the battery on one--still doesn't work. Tried to reprogram key fobs following instructions printed on several websites, including this one. The car does not enter programming mode (no clicks--opening/closing locks--after following sequence of key insertions and door opening/closing).
Doors open/close normally using key. Just the fobs don't work. Anyone else seen this problem? Might this be a bad fuse somewhere?
· ASE CMAT L1 MRRT
09 Avalon XL
This is a perfect example of how Techstream would make this diagnosis much easier. You can pick up a cheap Chinese knockoff cable and software on ebay and amazon that will interface with a laptop and you will be able to do most everything a dealer tech can do. The cable is limited but it will do what you need.
Discussion Starter · #3 ·
Actually, the cheapest and easiest solution seems to be to get a third-party key remote system. I got a quote from a local outfit to install one with two key fobs for $150. I haven't seen any used parts available for my 2005 Avalon anyway and the dealer wants over $600 just for the receiver. Toyota's notes on this issue indicates that other parts might need to be replaced if this does not fix the problem and their parts are non-returnable.
So for an 11-year-old car I will go the cheap route.
Thanks for your help anyway.
I am just guessing it's the Body Module that went bad. It's the module that controls the remote controls.
If the key still starts the car, the Immobilzer is still working and it's a separate device.
As the other poster said, Techstream should provide diagnostics that would pinpoint the issue.
Discussion Starter · #5 ·
You are probably correct but the body module costs more than $600 and is unreturnable should the problem lie elsewhere. For the record, I found a dealer who installed a third-party system that does all that the Toyota key fob does. It cost $159, including installation & tax and has a lifetime warrantee. The module has been placed under the dash out of sight. So far, it seems to be working perfectly but perhaps does not have the same range as the original part--but still perfectly acceptable.
· Official PITA
'05 Solara Convertible & '07 ES350
........ So far, it seems to be working perfectly but perhaps does not have the same range as the original part--but still perfectly acceptable.
RANGE: If you know where the receiver/controller module is, look for
a longish wire un-connected to anything- there's your antenna.
Add a foot of wire to it, you could solder the extra on if you want,
then stretch the antenna (sideways is fine) to full length
You'll find your range is now *substantially* better:wink:
found one on eBay for Toyota solara and worked perfect just make sure Fcc number matches ,
part number i used OEM # 89741-AA030
after installation both old remotes programmed perfect .
Hello
My 07 avalon has no working key fobs. Dealer says there's a short in the wiring.
I think its the receiver control module from all that I've read. Where Exactly is the
Control module? Behind the glove box? Under the drivers side dash?
How do I remove the module/receiver?
Can Car Toys set up an after market key fob and receiver to control the door locks and trunk?
thanks,
Location of the receiver; Fob certification computer is above the glove box.
Hello
thanks,
2 questions, where is the body control module on my 07 Avalon.?
Also, Where did you find the shop to install an after market key fob and door lock system?? Car toys and the toyota dealership won't do it by itself.
thanks.
Hello
thanks,
if there's short then a new fuse should fix the problem. sounds like dealer's BS
07 Avalon Limited
Here's a test
Turn the car on engine on then off (body ecu will stay on for about 5 seconds while it has residual energy if the fuse is blown)
Quickly get out and use the lock function on the fob if it works your fuse is blown and in 1 min it will not be working anymore
If this is the case check the fuses in the driver's side fuse box
1 - 15 of 15 Posts
