1 - 11 of 11 Posts
im in the process of replacing my brake fluid on a 2001 toyota 4runner which I'm ok with doing, but removing as much fluid as possible from the master cylinder is next to Impossible with a screen in the master cylinder. is there any tricks with removing as much fluid as possible ? any way to remove the screen so i can get the turkey baster lower? thanks for the help
Soylent Green sales
rock crawler
Are you going to flush the entire system or are you just replacing the fluid in the reservoir ?
1 - 11 of 11 Posts
