87 pickup 2wd, ext cab if it matters on braking system, sometimes when you back up it makes soem noise i assume rear brakes and then the light comes on in the dash, it can stay on anywhere from minutes to hours,
doesnt do it every time you back up and not every day
truck sat sunk in mud for about 6 years i know cuz the fuel pump was out i am told,
so the brakes all froze up and so alot had to be replaced, its a daily driver back on the road these days, for about a year now, very rusty chassis, it does pull a little to the right during higher speed harder stops,
thanks for any ideas what might be causing, you can hear the pass side rear drum if you are standing next to truck slow stops and the fronts work so good that they will lock up on gravel real easy, so i know at least that one's shoes are expanding, but i still think the rears are weak though and i may have to run new lines cuz everythings so rusted, what size lines do these trucks use that i need to get from the store ? i probably will have to reuse threaded fittings most likely i bet, ift hey dont get ruined trying to bust them loose and remove them
