1 - 3 of 3 Posts
G
Guest
I just check my front brakes on my 2001 camry, there is approx 2-3 mm left before touching the brake pad wear limit indicators. Should I replace the pads now or should I wait a bit longer.
thanks for the advice
--------------= Posted using GrabIt =----------------
------= Binary Usenet downloading made easy =---------
-= Get GrabIt for free from http://www.shemes.com/ =-
Q
Guest
Discussion Starter #2
The wear indicators, which are a good rule to go by, are set around 2/32"
or about 1.5mm. You're getting close, but unless it's going to drive you
crazy thinking about it you have a little ways to go before needing to
replace them. Just be sure that you look at BOTH pads in the caliper, as
they can wear at different rates.
J
You can calculate on the wear rate using the last pad change mileage.
I'd say about 5000 miles/mm for ceramic for typical driving. Again,
your mileage may vary.
1 - 3 of 3 Posts
