Might see something in one of these.
www.toyotanation.com
The Brembos were my past favorite, but the UV coating didnt do much in terms of rust build up. If they had a full coated line of blanks, back to being the ultimate combo.Brembo blanks and some Akebono Ceramics.![]()
True, riding brakes will do a number, but in practice I'd rather ride the brakes then place increase load on the driveline unless your in an emergency where you need all the help you can get to slow down.Riding the brake is the best way to warp rotors. Gear down when coasting down long hills. Unless you avoid riding the brakes, you will continue to need more rotors.
