1 - 12 of 12 Posts
Hello,
My corolla 2019 model, driven 73k kilometers, 3 month before change all 4 break pads front disc and back drum breaks,
past few days i noticed while parking the car, i hear the rattle sound coming from front tires, while pressing the break and put the Gear to D or R the noise come from front end.
so i went to mechanic explained all thestory, so he jack up the car and remove the two front tires and break pads then he says all looks fine, i told him something wrong in the break so he remove the break pads and installed it again, that time the noise not come, it was around 2 p.m.
then next morning again same noise come from front end, i discus this issue with one of my friend, he said the car was not drive whole night so the temperature outside was around 20 to 25 C, he says it is normal for all cars.
usually i parked my car at 8 a.m and again start the car at 6 p.m.
Any suggestion would be appreaciated.
Did you replace with OEM or aftermarket pads and brake shoes? Did you replace the rotors and drums or have them turned at the same time? Replacing the front pads without new or turned rotors is not good practice and may contribute to the problems your experiencing.
· イリジウム
Was the car moving when there was vibration? If the car wasn't moving and the car was vibrating, then it may be engine mounts.
It was hard to tell from the video.
Discussion Starter · #10 ·
This car not driven lot, very less used, per day not go above 20km , current odo meter reading 72k km only. Morning parked in office 8 a.m then 6 p.m to home,
This weekend will check again with mechanic,
1 - 12 of 12 Posts
