1 - 14 of 14 Posts
Does anyone know what the turn signal bulb size is for the 09's? im doing an LED swap and i need to kno what size they are...
Banned
This is straight from the Sylvania Website
"2009 TOYOTA Corolla
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
3457ALL
Rear turn signal
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
7443
Stop light
7443
High mount stop light
Assembly
Fog/Driving light
H11
H11XV XtraVision Halogen - The Brighter Light
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
168
Rear sidemarker
7443
Dome light
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp"
uh..no, it's not a hybrid
Just an FYI on LED bulbs. My bro-in-law tried to do an LED swap on his Chev Venture as they use turn signals for DRLs as well as he wanted to swap his rear signal bulbs to keep it even. After paying more than triple what a normal bulb costs, he was sadly dissapointed as the LED 'equivalent' was vastly dimmer. It was a brand name LED as well. More often than not the reflectors in the signal bulb housing are set up to capture a 360 light projection from the bulb, whereas LED's have a directional light projection, out the end of the bulb. So while they may state they have the same brightness, it may be only on axis and not in every direction like an incandescent bulbs.
This can be potentially problematic in heavy traffic as LED bulbs might not be seen from off axis, as well in inclement weather your normally visible rear end lights may be much dimmer with LEDs leading to potential dangers.
Also because of the much lower voltage drop across an LED your blinking rate will most often double or triple in speed.
As a result, he took them out and went back to normal bulbs,
Discussion Starter · #6 ·
I just swapped out my stock tail lights with leds. Realyy nice face lift and looks badass. Only problem is that sylvania.com states the rear turn signal is 3156. That is not true. The tail light bulb is 3156 and the turn signal is 1156. Just in case you wanted to change the blinker to led.
1 - 14 of 14 Posts
Looks like we ran into some issues. Please come back and try again later
