if you;re lucky, you just messed up the gasket replacement which is allowing coolant in. It probably slipped out of place whe you lowered the manifold....common issue on some models.
Was it doing this before you did the intake manifold? if so, then you probably got other problems... if not, and it only happened after you di d the repair.... go back in and try redo it again.
