How many miles are on the bottom end? And blue smoke I assume? It could be oil retaining rings (piston rings) if it's a high mileage or badly maintained motor. OR yes, valves; head gasket or cracked block also possibilities... If your oil temp went up maybe the oil pump is failing or there is some kind of clog or oil delivery problem or oil pump failure, that will cause internal damage pretty quick. how is oil pressure?
